A multicast forwarding entry was received with an invalid interface index - at least one interface does not exist or has not been enabled. The forwarding entry was not programmed.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Could not program a multicast forwarding entry for (%p1%,%p2%): invalid i/f index %p3%.
Name | Type |
p1 | VarFmtByteArray |
p2 | VarFmtByteArray |
p3 | uInt32 |
